Rs logic 5000
juad
Mar 2004
57
Hi
This is the first time itry to work with rs logic 5000 ,the disc is support versions
10.07.00 thru v 19.01.01 I installed the disc and try to go on line with control logic 5561cntroller 1756-l6 fixed in chassis type 1756-a4 I face the problem is the rev
Of the controller is 18.01 while the software is rev 19.01then I installed the rev support for rev 18 from the disc I get info to change the Plc rev which I can not do that because I don't know what is going to changed in the controller which is connected in production line also I try to open new off line file it is opened with rev 19 .i need help for the correct steps to solve this problem with no change to Plc rev also how to change the off line file rev.
Open a new offline file in rev. 18., then upload the PLC program from the PLC.
You can specify which rev you want the new offline program to be.
Just bear in mind that if you do update the PLC firmware it does wipe the PLC memory.
Thanks but as I said befor when I try to open off line file I have no ability to change the revision ,it is just one chose it is revision 19 even I installed again the revision 18support,I just install it ,is there any other step to be active or just install .............tanks
Good day everyone. if you have a logic for 3 pumps (lead/lag/off), would you please email it to me? I really appreciate it!
223
Uploaded this project from a PLC that we need to make changes to. I am trying to figure out the reason I am unable to open the actual logic. Do I...
2,254
Is there any way to install multiple versions of studio 5000 Logic Designer or do I have to install them all individually? Also, I am assuming...
2,443
Hello, I need help making a logic modification to a RS Logix 5000 program. I can email the program and give plenty of insight to it plus I have...
2,216
Hi. I have been dealing with this for years. Does anyone know why or, how my AOIs are not allowing me to look in on its running logic while I am...
7,660
