RS View Tag Query
MarkNightingale
Sep 2010
In The VAT Shed
740
I am using RS View to do quite a large project, so I am using pop ups for all my valves and pumps etc.
This means I have to use parameter files to populate these pop ups with the relevant information.
When I am adding the tags to the parameter file I am basically copying and pasting from the offline tag file. However I've noticed that some tags have :: in front while others don't.
I dont want to do the 200 odd valves and find out that I have got to go back to put :: in front.
I have given an example below.
#11 = ::[Saudi]N16:4
#14 = [Saudi]N77:32
Thanks In Advance
Mark
If you are talking about FTView SE or ME, and not RSView 32, then the way that studio handles tags is at best inconsistent, and at worst stupid.
Simple rule for resolving the above though: If the device tag address has a colon :)) in it, you MUST precede the OPC name with "::".
If there is no colon in the device tag address, do NOT use "::".
SLC, PLC5 - ::[DeviceName]FileNumber:Element
Logix: - [DeviceName]Structure.Element
I am yusing FTView 5.1 and with parameter files, I have noticed the following.
Accessing global tags, no double colon
#1={[saudi]TagName.element}
Accessing program tags, there is a double colon
#1={::[saudi]Program:tagname.element}
Hope this helps.
Well, again, the program level tags need to have a ':' in the address path, so you must precede the access name with '::'.
Simple... If the address has a ':' anywhere in it, you must prefix the access name with '::'.
If there is no ':', don't use '::'.
I have a German programed ME program. I want to know what tag in the PLC a latched button turns on. However when I open up the tag properties I...
208
I want to set user security level based on the value of a tag in my PLC called "ActiveUser". That tag will contain the A-P code which we use for...
224
Hi, I have an issue accessing tags in 3 of my plcs'. When I go to select a tag there is no folder drop down as can be seen in the photo. Any...
92
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
298
I have a FactoryTalk View Se project, Is it possible to export Direct Reference tags to edit in a CSV file or Excel? I know I can export HMI...
294
