rs485 vs rs232
martin3885
Aug 2005
Saarland
144
what are the advantages of using a rs485 bus in comparison to rs232? Where can I find a good informations about different interfaces?(rs485, rs232, Profibus, ProfiSafe and others too).
RS-232 is point to point only with a fairly low transmission distance, on the order of 50' (16-17m) max. Point to point is like computer to printer, no other devices.
RS-485 uses a differential mode that functions over relatively long tranmission distances, on the order of 4000' (1200m) max. Devices using RS-485 can run protocols, like Modbus or Profibus, that allow multiple devices to be wired in a multi-drop or daisy chained fashion.
Good recommended material by the others.
Dan
The rather excellent Westermo link has changed and can now be found here. Well worth a read, everything you wanted to know about Comms and Data Comms.
Bryan
i have an device which can support serial (RS485,RS232),CAN protocol . i want to connect it to an existing MIB 1553B bus ,what device will I need...
107
Hello: I have to connect a RS232 Modbus RTU slave that only has Tx, Rx and GND signals to a Modbus RTU master. However, all RS232 to RS485...
254
HI All, does anyone know if you have to change a cp 341 rs232 and use a cp341 rs485, what changes have to be made to get it to...
1,349
Hi guys Just wondering if anyone has succesfully read barcode data from these barcode scanners to a plc via rs232 or rs485? If so do you guys have...
1,471
I'm working on an application to have a ControlLogix 5561 communicate with a Telesis TMC420 pin stamp / dot peen controller. The Telesis unit has...
18
10,001
