RS5K changing tag names
robw53
Nov 2009
south yorks
515
we have a flour and oil dosing system which has all its tags etc in french, i have converted them all in google translate and i am just wanting to seek some advice before i commit myself to going through editing all the tags to english.
should i just be able to go through all my tags renaming them and the code updates as i change the tags, and then download the program back into the processor, or is there any potential problems i may need to be aware of when doing this.
it also has a PV 300 on devicenet connected to it to display silo weights, current seqeunce, etc will i need to change anything in that?
FYI
1769-L31 Processor
cheers
Rob
When you edit a tagname, the change ripples through the logic and gets updated - ie you shouldn't have to change any logic.
If the PV300 is of the plus series, you'll have to go through the PV300 tag database and update the names with the changes. If the PV300 is a standard, you may or may not have to depending on if you renamed the SLC style tags in RS5K.
(I'm pretty sure I got that last bit right)
Right click on any instance of a tag name in either the program or the tag list and choose edit tag properties and just rename the tag. All instances of the tag will automatically change. You do not have to necessarily rename tags offline, you can edit the name online. What you cannot do online is rename elements in any UDTs or AOIs.
thats great news, the reason i said offline was because its a monster program and the area were the panel is i don't want to spend hours in, but thankyou for reassuring me.
regards
Rob
A new behavior (at least new to me) that I see in v19 is that if a PV+ (or other device) is reading a tag via Ethernet/IP, the s/w won't let me delete or change the name of a tag while online.
thanks both of you.
I only have one app written from scratch with RSLogix5000, and the HMI tags are generically named arrays not likely to ever need tampering with, but it is something I wondered about.
I have an RS5k project setup for the L61 controller. I want to edit and test the project but I only have an L62 controller and so I changed the...
2,301
I have a 1769-L33ER compact logix plc that is currently running v20.12. The program does not have any source protection set up. I can upload the...
1,892
I am trying to learn more and deeper in RSLogix5K. For 1 machine here with a ControlLogix I have version 20.05, so I am teaching myself on that...
1,561
DoMore has the ability to format strings, and I can show timer acc as xx:xx once I move the value to a string. Is this possible in RS5K V24.11 ?
1,843
Hey, folks. I was looking on line at some videos and saw one about PID tuning and the guy had made a rung with a compute instruction using a...
1,158
