RS5K Fuzzy Designer
padees
Aug 2011
Michigan
916
Anyone use it? (we don't have it)
A couple questions.
If a function block were created in FD, would someone without FD be able to open the program and see the function blocks?
If not, are there any tell tale signs that Fuzzy Designer was used in the creation of a program?
We have a program here with gaping holes in it, and these are the areas the customer is having trouble with.
Just trying to rule things out. No one around here has it.
OK, think I found my answer. Create an AOI with FD and the world should be round if I want to open it without FD.
I talked to a lot of long time RA enthusiasts, and they have never heard of RSLogix 5000 Fuzzy Designer. You don't want to either, the add on is $6,300.00 :eek:
i made it in 61131 in ST and in CFC.
the calcs are all in ST, however to connect knots and keep it visible i used a complex structure same as in labview.
i love to sell it to you only 1000 euro.
I have a 1769-L33ER compact logix plc that is currently running v20.12. The program does not have any source protection set up. I can upload the...
1,872
I am trying to learn more and deeper in RSLogix5K. For 1 machine here with a ControlLogix I have version 20.05, so I am teaching myself on that...
1,556
DoMore has the ability to format strings, and I can show timer acc as xx:xx once I move the value to a string. Is this possible in RS5K V24.11 ?
1,836
Hey, folks. I was looking on line at some videos and saw one about PID tuning and the guy had made a rung with a compute instruction using a...
1,153
Hey guys I was looking through all the posts about PRINTING a program (RS5K V.20.04) but I don't want to print it. I just want to save it (PDF)...
1,426
