mellis
First off, I agree 100% with what Ken just said.
A couple more points...
The new Factory Talk activation scheme should be more robust than the floppy scheme it replaces under most situations. The easiest way to get your activation initially set up is via the web. But you should only have to do this once.
If the software is for a specific pc, you probably nodelock it to the MAC ID. Once you have the activation file, there is no reason to go back and reactivate from the web. It's just a file. Any backup method will work. With reasonable backup procedures in place, the only way you can be in a situation that requires reactivation is if the hardware that MAC ID is associated with is destroyed or lost. Then you have a problem that requires you to go back to Rockwell for help. But that's a pretty catastrophic situation.
That being said, there are some advantages to the floppy scheme that some of us will miss.
One place where the floppy scheme is more convenient is when you start out with it on a specific pc and then later on decide that you really prefer it on a different pc, you can move it with relatively little hassle. You can do this with the FT scheme if you plan it ahead of time, but it's kind of inconvenient if you don't. So, every few years when my pc gets replaced I may experience some extra pain. But I won't be in the field on a startup when that happens so it shouldn't be a horror story.
Another situation where the floppy scheme has an advantage for the end user is where you install your activations to a network drive and allow first come, first served access to multiple pcs. The new "floating" activation will let you do this too, and it has a better mechanism for managing the activations, but last I heard Rockwell wanted a 50% premium for each activation. That's definitely going to be perceived as an undesirable change to most users. But I'll wait and see how Rockwell responds. They already dropped the "only available in packs of 5" requirement which I think would have eliminated a lot of potential users.
Bottom line. I'll get used to the new scheme. It won't be that bad. I'll know what to expect and I'll deal with it. Most of the rants I have heard so far about it boil down to: lack of familiarity and lack of planning. And some just plain got the facts wrong. It's to be expected, nobody LIKES copy protection schemes. They are at best a nuisance to users.
