RSlinx Browse remote subnet
gakpapa
Mar 2008
jakarta
34
Dear guys,
i have question about RSLinx Claasic Lite
i have a server with IP 10.24.2.98, subnet 255.255.255.0
i have an ENBT, attached to the network with IP : 10.10.98.5, subnet: 255.255.255.0
the server can ping the ENBT
question:
what driver should i use on RSLinx?
is it Ethernet/IP driver using browse remote subnet?
or should i use pc for a gateway, and install RSLinx Claasic gateway?
Thanks a bunch for the answer :)
roe
Does the last octet mean anything? Technically the network's address is 0, but why does it give you the option in the first place?
1,590
We use RSLinx Classic Gateway for our AB PLC communications. The one issue we have is that even if you have your RSLinx configuration saved and...
3,503
Hi Guys, I have RSLinx Classic V2.59.02 and I am trying to Browse to PLC 1756-L73 through 1756-ENBT/A. I can view the ENBt card but can not...
2,278
I added several topics to an RSLinx Classic Professional (3.70) installation and was unable to add tags from the topics to Historian SE in...
1,790
Hi. I'm trying to connect to PLC via ethernet. In RSLinx I can browse the network and see the ethernet card. The ethernet card is placed in my...
4,255
