RSLinx Ethernet connection timeout parameter
curlyandshemp
Jul 2005
Toronto
1,903
Anyone know if the connection retry/timeout parameter for ethernet connections in RSlinx can be adjusted. I have had many occasions where I have used Who Active--> Go Online to the wrong ethernet based PLC in RSlinx and had to wait for the 10-20 sec timeout period.
Becomes frustrating when you are on a job site and the customer is screaming $100 per litre product is gushing down the drain and in the confusion to get online , the wrong unconnected PLC is selected , and the time out period has to expire before the correct PLC can be connected to.
Ian
Ian
Bump.....
Is this wishful thinking on my part this timeout can be changed?
Ian
Bump!
Anyone? Bueller? Bueller?
Seriously, RSLinx Enterprise apparently has a 60 second timeout whenever I try to do a "who active" and it tries to communicate with the last node. Is there any way to change the timeout?
Mike
I know several sharp motivated folks who have tried to fix this, to my knowledge there is not an answer?
I am very interested in this too!
I am using a VM for my Rockwell software, and have been having a weird issue. Essentially, I configure my devices in RSLinx using the Ethernet...
5,874
My network connection on my lap top no longer works. It just says network cable unplugged. This same thing happened on another laptop, that the...
26
7,611
Anyone have experience using serial to Ethernet converters to connect to SLC and Micrologix devices? I am looking to build a remote access box...
1,365
How does RSLinx Classic EtherNet/IP Driver "Windows Default" adapter relate to the all of the available Windows adapters? Is there a way to...
2,523
Does the last octet mean anything? Technically the network's address is 0, but why does it give you the option in the first place?
1,599
