RSLinx Ethernet/IP driver on a VLAN
ccamp
Apr 2013
Arkansas
17
1. I am having trouble getting a new computer set up on RSLinx using the ethernet/ip driver. I have VLAN with multiple subnet's, PC's, Servers, Devices (PLC's), ect.
2. When I go in to driver configuration in linx and select Ethernet/IP driver I choose "browse remote subnet" (which is how all of my working computers are set up) I put in my subnet IP address for the devices i'm looking for and mask and press OK. When I go into RSWho and browse nodes it never finds anything.
On a working computer already configured with the ethernet/ip driver set up the exact same way I can find all nodes on the subnet. BUT, if i take a working computer and create a new identical ethernet/ip driver it doesn't work.
So I have working computers with this same driver set up in the past and everything works perfectly. But if I try and create a new ethernet/ip driver on any of my working or non-working computers it fails to work.
If IP directed broadcast or any other broadcast service was disabled on my router none of my computers would be able to browse any of the subnets thus everything would not be working.
Does anyone have any ideas??
How does RSLinx Classic EtherNet/IP Driver "Windows Default" adapter relate to the all of the available Windows adapters? Is there a way to...
2,501
Hello Friends, 1. How can I connect to PLC5/30 via Ethernet (Rslinx)?. I have not worked on PLC5 before. is it same procedure as MicroLogix...
2,192
Under the "Ethernet devices" driver from RSLinx, I see all my remote devices when my laptop's wifi is enabled. Under the Ethernet/IP driver, I...
4,885
Hello, Any help! My Rslinx classic with version 3.8, Ethernet /IP Driver cannot detect anything within the network, but using the ethernet...
6,767
I am having an issue where we just implemented a VLAN switch (NTRON brand). The switch seems to be working fine. I can ping the devices and also...
4,486
