rslinx quits during upload WIN 7
realolman
Mar 2009
here
584
I am trying to upload a file from a panelview 600 and all it has are serial ports.
I finally got the thing to communicate and in the process of uploading with Panelbuilder 32 it seems to lose connection in RSLinx
It works for approx. 30 sec or so... At one point I got 17% of the file uploaded ...that's the most
Help Please
thank you
Look at configure CIP options in RSlinx. I have mine set up as follows:
Fast PCCC request checked
Slow PCCC request hecked
Messaging Connection 8.0 sec.
Max fast 1
Max slow 1
Max unconnected 4
DH+ interface 4.00 sec
Max fast 4
Max slow 2
PanelBuilder32's file transfer utility might also allow you to use its internal drivers, rather than RSLinx. Give that a shot.
If the PanelView has version 3 or later firmware, you can use an ATA style PCMCIA memory card. Even a CompactFlash card formatted for FAT16 (under 2 GB) will work in a Type II PCMCIA carrier.
thanks for posting ... It has ben a looney bin here today ( as usual ) the USB to serial is a Gigaware (Gigabyte... sheesh )
Ken, I don't know what you mean.. I thought Panelbuilder used RSLinx. How would I do it without RSLinx?
Also, for what its worth, I uploaded the file from the panelview 600 in first shot without a hitch using the old XP computer and Panelbuiler 32 ... does that indicate anything other than the obvious?
Cornbread... I tried your settings ... It was about 10 times slower than the XP computer was ... It did make it to 27% which was the highest I was able to go with the WIN 7 computer, but it still quit
thanks
Wait a second. Did you say you're running PB32 on a windows 7 machine? I thought that PB32 was incompatible with Windows 7. What version of RSLinx are you using?
Did you use a real serial port on the old XP?
no... it was a gigaware usb to serial converter
well, that's what I was trying to do, yeah. I don't know the version ... I'm home now
I think most everything is incompatible with WIN 7 I was hooked up to a controller with RSLogix 5000 today and it wouldn't do much of anything right... I finally went and got the XP machine and fixed what was wrong... I don't know what to do with that WIN 7 machine... I think they (Rockwell and MS) should have this stuff ironed out long before I get it
They do it depends on what versions you are running. PB32 is for standard PVs. The software was probably first created in the late 1980s. And the standard PVs are obsolete now. So expecting it to run on windows 7 now is a little unrealistic.
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
197
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
231
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
159
I need to support some old data collection that is running on Excel, but I need to get it running on LibreOffice. The following statement works...
91
Hey All, I am sorry to ask this, but i still gotta do it. What happens if I close RS linx? Will it cause network interruption and PLCs will lose...
162
