RsLinx yellow question mark
ARose110
May 2019
Lebanon,PA
Good morning all,
I am having a problem seeing my some devices on rslinxs I do not have a X over it and I can get online with the the two devices. I tried uploading the eds files from the device, and went through all the steps and had no issues.When I opened up Linx's again I still have the yellow question. I am running rslinx, rev 4.11.00 and my computer is windows 7 OS. Any help would be appreciated.
Usually closing and opening RSLinx is all that is needed to refresh EDS info. Have you tried rebooting the computer? If the RSLinx service is running, closing and opening might not be enough.
OG
I just tried rebooting my desktop computer and no luck I still have the yellow question marks. I did do a reboot on my laptop windows 10 OS, and it worked I can see the PF graphic image
I'm having an issue where there is a yellow question mark for the 1756-enbt/a. I've installed the EDS file along with uploading eds from device...
1,117
Hi community! Before I installed CCW my RSLinx was working fine, but after it, I cannot connect to some PLC's in the network and all the devices...
1,492
I am having issues with communicating with contrologix devices on a ethernet network. We have several SLC 505's on the same network and can see...
7,669
I met a yellow question mark on Rslinx for Schneider HMI STU855. The loop connection is my PC, 1761-net-eni, switch, HMI. I can see ENI and HMI...
8,432
Hi, I have just setup another computer with studio 5000 on our network. The issue I have now is that when I use the Eth driver and enter the IP...
1,812
