RSLinx Yellow Symbol
robw53
Nov 2009
south yorks
515
I have just setup another computer with studio 5000 on our network. The issue I have now is that when I use the Eth driver and enter the IP address of the device, it picks it up and recognises the device type and also the project name in the program, but the device shows yellow and won't allow me to connect with studio. At first I thought it was the EDS files but I have installed version 30.01 and even tried uploading the EDS from the device, but I get the message that I have newer EDS files installed.
I remember back in 2014 when the other PC was installed on the network, that the IT guy at the time had to go into CMD and do something with the NIC to let it see devices on different VLANS etc, but can't think exactly what he did. I believe that what he did then, allowed me to see the devices.
Anybody got any ideas as to what this might have been?
Regards
Rob
From memory I know when he had CMD open I had to enter all the different subnets I wanted to be able to see from the PC.
I believe this may have been the routing table that we configured, would this cause the issue of not seeing the device properly?
I'm not at work so can't even look at the other PC to check it.
I'm having an issue where there is a yellow question mark for the 1756-enbt/a. I've installed the EDS file along with uploading eds from device...
1,115
Hi community! Before I installed CCW my RSLinx was working fine, but after it, I cannot connect to some PLC's in the network and all the devices...
1,492
Good morning all, I am having a problem seeing my some devices on rslinxs I do not have a X over it and I can get online with the the two...
1,910
I am having issues with communicating with contrologix devices on a ethernet network. We have several SLC 505's on the same network and can see...
7,669
I met a yellow question mark on Rslinx for Schneider HMI STU855. The loop connection is my PC, 1761-net-eni, switch, HMI. I can see ENI and HMI...
8,431
