RSLogix 5 issue
Dallin
Feb 2007
Ontario
43
Over the last week our shop computer has developed an interesting problem. We have about 15 PLCs all networked back to our shop and recently we have developed a problem with 3 of them.
Normally we just connect using the Who all function and double click on the plc that we want to connect to and it does the usual load up the prog and then goes online with the processor. Now 3 of them generate a page fault error and crashes out of RSLogix. The only way I figured out to get online with these processors is to load an offline image and then do a processor upload. After the upload I then get a prompt to go online and it works fine.
I am thinking that those 3 files have gotten corrupted somehow but I can't confirm it. Even loading up a back up copy or loading in a backup from a floppy does not fix it.
I am thinking the hard drive is telling me that its on the way out and we may soon find we will need to do the upload for more plcs soon.
Just wanted to see if anyone here has seen something like this before.
I had a similar issue with one of our racks--I eventually corrected the issue by going off-line and then re-downloading the program into the rack.
My guess at the time was that someone had the program open and didn't shut the PC down properly, corrupting some portion of the program.
Rockwell Software could tell you for sure--
Thanks for the reply. Probably the only thing I did not try as we run 24 hours a day 5 days a week. Will try and get the weekend guy to reload it.
190
I had a student fooling around with settings tonight, and now when I try to print a program ladder, each rung prints on a separate sheet. Too many...
364
Hi ,I'm new to plc programming I have old controllogix plc with 1756-l55M12 controller I downloaded trial version of rslogix 5000 v16 I was able...
1,624
Hi All, I have a new 5 PLC system. Each has the same firmware revision. Each PLC has the same User Defined UDT for Safety Tags. PLC1 reads from...
2,020
i have an issue in redundant plc RSlogix 5571 the screen appears "TEST"on the with the OK red lED on. then goes to wait with green SD led then...
1,553
