RSLogix 500: "FILE N12:24 LEN:5 - FLL - File #10 - 8"
AutomationTechBrian
Jul 2013
St. Cloud, MN
669
I'm troubleshooting this machine in the field right now. The discrete outputs of this Micrologix 1500 are wired to discrete inputs of a Siemens S7-200. On the MicroLogix, three of the outputs on the drawing are labeled as BCD 1, BCD 2, BCD3, which are the first three bits of N12:24. All I can come up with for "BCD" is binary coded decimal... not sure about that, but it would make sense. Any thoughts? I suspect this is telling the S7 (slave) what pattern to follow, but it's just a hunch.
I looked in the cross reference to see where N12:24 originates and I see "FILE N12:24 LEN:5 - FLL - File #10 - 8". Hmmm.... I don't know what that is. Thoughts?
I figured FLL out... I should have figured it out earlier. Len: 5 was just "length". Nothing weird... it was just re-setting the machine by filling 0s into all the number bits. Sorry... I've been staring at this too long.
I'm still thinking about BCD, though.
I have seen this done many times, it's usually a simple way to sent limited data to another PLC 3 bit BCD = 0-7 decimal 4 bit = 0-15 8 bit = 0- 256 so it could be sending a range of 0-7 for example recipe number but limited to 7 or some other function. Another example is the Mitsubishi VFD's have 3 inputs to control the speed as well as analogue, the 3 inputs are designated as low med high, however by setting these as binary numbers you actually get 7 speeds.
I have even used a 16 way digital output card as crude communications to another PLC (many years ago before communications were limited) 8 bits were used as address & 8 bits as data, it was slow but worked well.
I stumbled onto this behavior the other day, then went looking for old forum posts with the assumption that "there is nothing new under the...
784
Hello All, I am working on converting a program written in RSLogix 500 to Connected Components Workbench. The MicroLogix to Micro800 converter...
1,209
Hello All, I created the shortcut while setting up comms in FT View to a Logix 500 processor, then a offline tag file to the processor .RSS file...
1,729
Hi Guys! Does anyone know which version of RSLogix 500 i can insert ASCII DataFile? I'm using 10.0 version and i not found this DataFile, but...
1,456
Hello all I have a file that I’m having issues opening. It’s off an old machine and I don’t have rslogix 500. I only have 5000. Can someone please...
1,768
