RSLogix 5000 and FactoryTalk View Studio Question
Please understand, I'm not being critical, but for a programmer (other than the author) to come up and understand what the program is doing requires that tags and rungs be annotated (descriptions filled).
- Simplify the rungs. In my opinion, there can't be too many rungs. And put a comment in the rung comment describing what the rung is doing, even if its a simple sentence. It helps someone like me, a virgin to the code; KISS method is best.
- I always use timer done bits to drive new tags (unless they are used in the same rung as the timer). In the tag comment, describe what the tag represents.
It may seem like a lot of unnecessary work, but programmers and/or electricians that have to maintain the code later will thank you.
alright. I understand. i will make the changes and add the comments to the north and east so that you see what i am trying to explain
I am not sure if I used the compare function correctly. I was attempting to make it so that after the car passes through the light, when i activate the car, then it will reset back to 0.
0---> no car
1---> car on standby
2---> car goes
All the Sources in the Mov Function are just tags that i created to transport the value that i wanted from 0-2 to go inside the destination which was the next tags. the destination tags went to the factorytalkview studio. they didnt serve any other purpose in my code
Hello all, I have the misfortune of needing to support some old firmware version 1756 controllogix machines in rslogix 5000, as well as some...
971
Recently I shared an RSLogix 5000 (v30) project file with a colleague. When he attempts to open the file on his computer a FactoryTalk login...
10,477
I was talking to my Rockwell distributor through email and maybe he missed part of my question, but I was led to believe that Factorytalk Studio...
3,672
Hi all I have a compact logix plc with a program and a panelview plus Me hmi with a program ,all work ok but I have noticed that there is no...
8,199
i have factorytalk application (.mer) and rslogix 5000 application(.acd) and the are some problems in factorytalk application some trends are not...
3,895
