Hey there,
I'm trying to compare the amount of counts in any 5 minute period.
What I'm doing so far is when each count is made true, a binary 1 is moved into a DINT array with a BSL command. If the count is not true then a 0 is moved into the array with the BSL.
Then, I'm using a MVM mask to only output the 5 least significant bits of that array into a final DINT array.
I would like to compare the final DINT array to see if there is 3 counts in the 5 minute period (though not specifically next to each other).
Is there a way to 'count' the amount of true bits in an array?
