rslogix 5000 compare tool error
unsaint32
Oct 2012
minneapolis
365
when I use rslogix 5000 compare tool for two particular ACD files, I get an error "an entry with the same key already exists." It happens onlly when comparing these two files. I can compare other ACD files just fine.
Both ACD files to be compared are fully functional and I can edit them using the Studio 5000 with no problem.
Any idea about the cause of the error?
Studio 5000 Logix Designer Version 21.00 - Service Edition
RSLogix Compare Error
I'm having the same issue. Someone knows why are this happening?
When I try to compare two .acd files i get this message: "An entry with the same key already exists. Additional Info: Project XML file is not formatted properly."
I already tried to export the files into .l5k, but I get the same error.
I'm using:
RSLogix 5000 Professional/Network Edition V20.01.00 (CPR 9 SR 5)
RSLogix Compare v3.20.00 Build 87
Thank you in advance,
Hello, Currently on my laptop have rslogix 5000 v16_20 and I'm not able to see the compare sheet of parameter for vfd powerflex 40p over comm e...
1,287
Hey there, I'm trying to compare the amount of counts in any 5 minute period. What I'm doing so far is when each count is made true, a binary...
2,673
Does anyone use the Compare Utility from RSLogix? I would like to use it in a batch mode if possible. Can it be run from the command line with...
5,479
What does "mv" mean on the side of the comparison windows in RSLogix 5000?
2,667
I am scanning 6 bar codes (6 different scanners, each scanner scans one bar code) into the PLC using network cables and it stores them in INT(67)...
9,217
