RSLogix 5000 Compare Tool
dadof3and3
Jan 2013
Texas
Does anyone use the Compare Utility from RSLogix? I would like to use it in a batch mode if possible. Can it be run from the command line with inputs parameter for the files to compare...
Thank you!
I was also looking into this as I hoped to set it up as the external merge tool for SourceTree. You can use Process Explorer to view all the strings in a running program and usually that will show you the command line options as well. When I did that for RSLCompare.exe, the very first string it shows is "!This program cannot be run in DOS mode.".
However, it also has hidden in the strings this information:
"Command-line input should be of the form:
RSLCompare.exe BaseLogixProject[.L5K|.ACD] CompareLogixProject[.L5K|.ACD]
RSLCompare.exe BaseLogixProject[.L5K|.ACD] CompareLogixProject[.L5K|.ACD] CompareToolProject.compare
RSLCompare.exe CompareToolProject.compare CompareToolReport.pdf
RSLCompare.exe [/d]
Where /d creates an XML dump of the project at ProjectName.xml"
Sure enough, running RSLCompare from the command line with the /d switch brings up a prompt about how to use RSLCompare from the command line.
EDIT: I've tried a few tests and I can't for the life of me get the /d switch to do anything.
Hello, Currently on my laptop have rslogix 5000 v16_20 and I'm not able to see the compare sheet of parameter for vfd powerflex 40p over comm e...
1,293
Hey there, I'm trying to compare the amount of counts in any 5 minute period. What I'm doing so far is when each count is made true, a binary...
2,676
when I use rslogix 5000 compare tool for two particular ACD files, I get an error "an entry with the same key already exists." It happens onlly...
14,091
What does "mv" mean on the side of the comparison windows in RSLogix 5000?
2,669
I am scanning 6 bar codes (6 different scanners, each scanner scans one bar code) into the PLC using network cables and it stores them in INT(67)...
9,229
