RsLogix 5000 v19 Alias Tags
wperriman
Nov 2012
Ontario
25
I have a project I am re-doing and would like to clean up the I/O tree by removing some un-used modules.
I know in order to delete them I need to remove all tags and alias tags referencing the modules.
My problem is that I can't delete the tags aliased to the module tags. They are 'greyed out' and not available to edit.
None of these tags are used in the logic anywhere and I don't see what condition is preventing me from deleting the tags.
When I cross-reference the module by tags it looks like there are multiple tags with the same name, just different alias. Not sure how this condition exists. I have attached a screen shot.
The condition of uploading the file causing problems with nested alias' has been discussed and is a real possibility in this case, if so, what would my next steps be?
Thanks for any advice.
All of the other tags in the file are acting like I would expect.....
Module tags cannot be edited, alias tags can, etc....but these tags are different.
Those are still all module defined tags. Delete the modules and those tags will go away. You are seeing some tags that look like alias tags but those are the result of rack optimized connections.
Delete the module in slot #1 of that point I/O and you should see all of those tags go away.
OG
Thank you, I thought I needed to remove the tags before the module could be deleted.
Are rack optimized connections set up automatically with that type of module? I haven't run into that problem before.
Yeah anytime you add a remote digital module it defaults to a Rack Optimized connection, which isn't necessarily a bad thing. But, the additional tag/alias can be confusing.
I believe if you delete the module while online without deleting an alias, it will warn you. Offline, it will go ahead and do it, and the orphaned alias tags all show errors.
OG
Ive recently been having trouble with the stability of my connection when online with a plc, The software intermittently freezes (cogwheel...
2,073
V19 does not run on my Windows 10 laptop, I tried everything - run as administrator - compatibility Vista, 7, XP - reinstall .net framework Has...
5,293
Hi guys. Sorry for my english. :rolleyes: I have some problem with RSLogix 5000. I worked with version 20 with any problems. I'm working on...
4,776
Hello. I was working on commissioning some control logix programs when I somehow lost the ability to force I/O's form the controller tag screen...
3,670
Hi guys, I've tried to install Rslogix 5000 V19 on Windows 7 Ultimate 32 bits but get a message that says "RSLogix 5000 is not supported on...
3,221
