RSLogix Emulate 5000 Restore Image not working
PAPO
Apr 2014
Canada
Hello !
I'm using RSlogix Emulate 5000, and everything seems to work fine the first time I download a program, using RSLogix.
BUT as soon as I restart RSEmulate Chassis Monitor (after rebooting the computer for example) I loose some of them.
The slots still exists, but they get stuck in "Power-Up" mode... in the state "Restoring image".
I know I'm not the only one to whom it happens, and I already stumble uppon this post : http://www.plctalk.net/qanda/showthread.php?t=69925
Which has great answers, and let me at least remove a stucked Slot... But in the long run, doesn't correct my problem.
What makes me wonder, is that it ALWAYS fail for the same 2 programs. The other one (in another slot) reboots perfectly.
So, can it have something to do with the program itself ? If yes, then why does it work well the first time? Is it because I used RSlogix instead of the Restore feature directly from RSEmulate?
And even by Saving and restoring a snapshot of my *.ACD (using the feature in the Chassis Monitor), RSEmulate cannot seem to restore the image.
Has anyone found a solution to this problem?
Thanks!
Respected Members I try to install RSlogix Emulate Version 20.04.00 but the error occurs during the installation which is shown in the image...
973
I have RSLogix Emulate 5000 v21. How upgrate it to v31?
1,116
I want to to communicate a panelview plus with an RSLogix emulate 5000 and I know that this is not possible by RSLinx Enterprise, how can I do it...
2,743
I have an existing Compac Logix program and I would like to run it using the RSlogix 5000 Emulator. is it Possible can some bocy give me directions?
2,256
We’re looking to setup a stand-alone training station with FT View and a connection to a simulated plant system which would match the RSLOGIX 5000...
3,772
