RSLogix Pro Simulator - DO NOT HIT CTRL-X
ProgRambo
Jan 2017
Hawaii
Ok, so I'm sure this is old news as this program has been around for years and years. I'm new to the ladder logic scene and have been working with this program for the past month or two. I just selected an item and hit ctrl-x for the first time thinking it was a 'cut' and the program completely closed out without saving the project I was working on. Wow!
I would of hoped that it would of at least auto-saved before closing. Good thing I'm a 'save-nazi' and didn't loose too much info. Looking in the File pull-down, ctrl-x is indeed labeled as 'Exit'.
I doubt there is a way to disable this but if anyone has any ideas, I'd appreciate it.
You could use exteral software like autohotkey or another scripting software that will intercept the keystrokes when that certain program is active.
This was nice program. Even autosaving is possible to code with this if original program don't have autosaving.
So, I have a little dillemma I am trying to work through but I feel there is probably a better way. I've always liked the idea of using a VM in...
2,065
I have some software that requires the use of rslogix 5 professional (Auvesey Octohub) But now that Rockwell no longer offers Pro licensees I am a...
1,557
I want transfer my I/O data from schneider (Unity Pro) as a write data and RS Logix 5000 as a read data. I use Ethernet as an communication...
699
I am trying to move an RS5000 21.03.01 install on a Win10Pro machine. Currently have this existing setup on another Win10Pro machine. The only...
1,412
Hi, I’m looking at the difference between standard and pro versions of RSLogix 500. I know the pro version lets you edit the database in excel...
2,773
