RSLogix/Studio 5000 Capture/Track Previous Value
ohnedich6
Jun 2014
Midlands SC
67
Good day all,
PLC: RSLogix/Studio 5000 using Ladder Logic
I've been toying around with the idea of capturing the previous value of a tag inside of my PLC, but I cannot seem to get started with the best way of coding this. I was hoping I could get some help with this.
I would like the tag Previous_Tag to be able to capture the value regardless whether the number increases or decreases. Also, the value may change in an inconsistent manner/pattern at times (I.E. 1 ->4, 4->11).
Thank you for your help.
-Nathan
Pretty Basic 101....
Initial Previous Tag to Current Tag on startup (MOV Current Tag Previous Tag)
Then standard logic
If Current Tag <> Previous Tag, MOV Current Tag Previous Tag
If you have the following parameters:
TAG
THIS_TAG
PREVIOUS_TAG
Compare TAG to THIS_TAG if not equal then using a one shot Move THIS_TAG to PREVIOUS_TAG and TAG to THIS_TAG
Hope this helps.
Regards,
Is the Tag you want to look at a input value? If so are you buffering your I/O?
Remember that the 5000 family of controllers update their inputs Asynchronous to the controller scan. So the controller could update a input value before you get to your MOV Logic and you may not actually capture the true previous state.
Bullzi,
Its a memory tag which will eventually be used inside of an AOI.
-Nathan
robertmee,
I use the NEQ and MOV to determine if a transmitter's reading has frozen, but for this logic it is performing so fast that by the time I can look at the PREVIOUS_TAG it is already equal to the TAG & THIS_TAG.
gclshortt,
Thanks for the suggestion, but all of the values end up being equal to TAG almost instantly.
-Nathan
All,
Scratch the second part of my previous post with regards to gclshortt. I had a destructive rung of logic that I did not notice *face palm*. Once I deleted that it worked beautifully.
Thanks very much for you help.
-Nathan
So, I have a little dillemma I am trying to work through but I feel there is probably a better way. I've always liked the idea of using a VM in...
2,055
I have a micrologix 1100 that I am trying to read three data points from it on my safety plc using studio 5000. Any tips or guidance is appreciated.
849
Dear Sir, We have Windows 10 Dell laptop with RSlogix Studio 5000 installed in it. Now we have purchased a ex-proof laptop with Windows 10 and...
2,621
How can I achieve the same functionality in Studio 5000? Image 001.png for the old RSLogix500 program Image 002.png for conversion to Studio...
2,527
Hello all, I am working on a project on a CompactLogix L16ER-BB1B plc, and I was given a program that is on version 20.019, while my plc is on...
1,848
