RSLogix500 and GML commander
malbec
Nov 2013
israel
I have backup files of a machine that has an SLC500 and 3 motion controllers by Allen-Bradley.
I can open and see the RSLogix file. The GML files cannot be open, i get an error by the GML commander "Unexpected file format".
I also know that the devices have DeviceNet communication between them.
I have some questions:
1. How can I know which parameters transfer by the DeviceNet? Can I know it from the PLC project?
2. Is there another way to open the GML file? I have GML commander Version 4.00
Hi
The best way to see the mapping from the controller to the plc is getting rs networks for device net and then uploading from the scanner card. Them you will see what nodes are connect are where they mapped to in the plc.
As fir the gml I only ever worked on it a few times I know you needed to have the source code to be able to open it as you could not upload it.
The error you are getting at a guess that the program was created with a newer version
Donnchadh
So here's my situation, I have been tasked with modifying the logic to mimic a button press in the PLC. I have two identical machines however one...
541
Hello, I'm new to programming. I'm using RSLogix500 to modify an existing program for a SLC500. My plan was to use one of the existing inputs...
26
1,989
So i have an allen bradley rack (2080-LC50-24QWB), i have it connected through ethernet. I dont have an offline program so im trying to upload...
683
Hi Everyone, I am supporting a system which runs on a SLC 500 (1747-L532). A fault has developed whereby the output state of some digital outputs...
1,001
Hello, I am currently taking a course on plc programming and in the course rslogix 500 is being used. I am however having a problem since it keeps...
1,705
