RsLogix500 - No Matching File Found
gbeaker
Sep 2012
earth
148
Hi Guys,
I have a SLC 503 CPU that I go online with fairly often and never have a problem. Today when trying I got a "No Matching File Found" error. There is nobody else here to go online or modify files and I am 100% sure I am using the latest file. The processor name and type match and even the program checksum matches. It doesn't even give me an option to upload a use file. There is no password either. I'm stumped. Anyone have any ideas?
Thanks!
Please explain. The checksum still matches. Why won't it let me at least upload a use file? I would like to know how RsLogix determines the file isn't a match even though all the obvious stuff matches.
just a guess - but instead of clicking "Go Online" click "Upload" instead ...
I have ZERO explanation - but I know that in some cases in the past that has worked when everything else has failed ...
good luck with it ...
If you are doing this without the source file loaded, then RSL is looking in the wrong directory for the source file when going online. Or you may have inadvertently saved it the last time to a different folder (ie two copies on your drive, the last one and the one before that).
I agree it may just be the directory it is looking in is not the one where the file is stored.
Verify the directory it is looking in and/or use the Browse option to go to the correct directory.
So here's my situation, I have been tasked with modifying the logic to mimic a button press in the PLC. I have two identical machines however one...
541
Hello, I'm new to programming. I'm using RSLogix500 to modify an existing program for a SLC500. My plan was to use one of the existing inputs...
26
1,991
So i have an allen bradley rack (2080-LC50-24QWB), i have it connected through ethernet. I dont have an offline program so im trying to upload...
683
Hi Everyone, I am supporting a system which runs on a SLC 500 (1747-L532). A fault has developed whereby the output state of some digital outputs...
1,002
Hello, I am currently taking a course on plc programming and in the course rslogix 500 is being used. I am however having a problem since it keeps...
1,710
