rslogix500 w/sp2
jimpad
Sep 2004
Paducah, KY
88
I've gotten a job using a SLC/504 (this is my first AB job). It looks like I'll need the rslogix500 software to program the PLC, my questions are as follows.
1. Is rslogix500 the correct software?
2. Does rslogix500 run on XP w/SP2?
3. Should I have any concerns with having Directsoft (Automation
Direct Software) and rslogix500 on the same laptop?
Thanks in advance.
Jim
and don't forget that you'll need a communication cable between your computer and the SLC ... is there anything (barcode, Panelview, etc.) already plugged into the bottom (DB9) port on the front of the processor?
Thanks guys.
Yes, I'll be using a panelview. At first I'll be developing on my local AB distributor's demo case so I'm not quite sure what hardware he has. What type ports does the 504 have?
So here's my situation, I have been tasked with modifying the logic to mimic a button press in the PLC. I have two identical machines however one...
539
Hello, I'm new to programming. I'm using RSLogix500 to modify an existing program for a SLC500. My plan was to use one of the existing inputs...
26
1,985
So i have an allen bradley rack (2080-LC50-24QWB), i have it connected through ethernet. I dont have an offline program so im trying to upload...
680
Hi Everyone, I am supporting a system which runs on a SLC 500 (1747-L532). A fault has developed whereby the output state of some digital outputs...
999
Hello, I am currently taking a course on plc programming and in the course rslogix 500 is being used. I am however having a problem since it keeps...
1,702
