akosimalakas Member A Join Date Aug 2020 Location Manila Posts 16 Dec 4, 2020 #1 How to fix this error?
Mickey Lifetime Supporting Member Join Date May 2003 Location Palmdale,Ca Posts 10,659 Dec 4, 2020 #2 See link.. Post 9 thru 15 http://www.plctalk.com/qanda/showthread.php?p=696055
parky Member P Join Date Oct 2004 Location Midlands Posts 5,748 Dec 4, 2020 #3 N Variables are integers (16) bit, Floats are either 32 or 64 bit. you need to do the maths in F registers then if required convert to an integer
drbitboy Lifetime Supporting Member Join Date Dec 2019 Location Rochester, NY Posts 8,090 Dec 4, 2020 #4 this should work
akosimalakas Member OP A Join Date Aug 2020 Location Manila Posts 16 Dec 5, 2020 #5 it works sir. thanks
Saffa Member S Join Date Feb 2012 Location Bay of Plenty Posts 1,468 Dec 5, 2020 #6 Are you trying to scale an analog? If so, use the SCP instruction if your controller supports it. Much easier for others to follow.
