RSLogix5000 & CompactLogix
... eehm, and how is it when i want to use at my network modul
(1734-AENT) some 8-channel-digital-inputs/outputs (1734-IB8/OB8)?
... because i cannot choose them ...
Do I need a more actual version than RSLogix5k V13???
RSLogix5 V.13 will work fine.
Once you add the 1734-AENT module, in the "General" tab of the Module Properties, you must set the Chassis size to something greater than 1. The first slot is reserved for the AENT. If you want to add an I/O module, set the chassis size to 2 or greater.
Yeah, i found that allready out by myself, but when i turn the
chassis - number to 2 or more i can choose modules like 1734-IB2/4
but not IB8´s or OB8´s as shown on the following picture´s.
-) PLC & ethernet - ports:
-) and when i want to add a new module at the 1734-AENT
This is so funny. I just was fighting this yesterday. You have to go to the Rockwell web site and download new I/O module profiles.
PaulB
OK... now i see a little bit more clear.
But after this procedure (IB8 in this example) it looks like this:
So where do I have now my 8 - Inputs? Because now it looks like I
have 5 * 8In´s?
With digital - output it looks all ok:
Motion control by RSLogix5000,Compactlogix 5370 L3 Controller & 2097-V31PR2-LM Drive Hello! I would like to study the Motion control by using...
4,235
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
128
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
428
Hello everyone, I have an RSLogix5000 project which is running live in the factory but I need to make some changes to the logic. I want to test...
1,126
Good Morning Everyone, I'm looking to use the GSV instruction to get I/O fault codes for my project so I know if there's a comms issue in my E/IP...
873
