RSLogix5000 Print options...
crazylizz
Sep 2007
S'Western Ontario
Hey guys,
I know I'm new here, and I tried the search button, but no luck. Perhaps I was searching for the wrong keywords...
I'm currently using RSLogix5000 and I have a question in regards to printing.
I know with previous versions of RSLogix there was a print preview option where you were able to scale down the page prior to printing.
I have a lengthly program that I would like a hard copy of, but the 12pt/14pt print font is too big. I'd really love to scale it down and save some paper (not to mention being able to see my entire rung on one sheet instead of 3)
Is this possible?
Thank you for your time,
-crazy
Printing was essentially shoved to the very back burner with RSLogix 5k, and at release 16, I don't have any hope of it ever getting better :(.
Best you can do, is print on a large format printer, or print to another document format, and try to manage that (like PDF).
Damn.
Not good news :(
But thank you very much for the fast reply.
We should bug AB/Rockwell till they fix it :D
Admin you can close the topic now, my question has been answered.
Thanks rdrast
Crazy:
I'm using version 16 but i hope this is gonna be the same for other versions. Please look at the figure attached.
Change your font here.
You can also try to print the report in pdf format so you can see it before it gets actually printed.
Hopew this will helo
Morning all, In RSLogix 5k, is there a way to print the IO configuration? I thought I could get that info saving as the L5K but I didn't see it in...
1,107
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
124
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
428
Hello everyone, I have an RSLogix5000 project which is running live in the factory but I need to make some changes to the logic. I want to test...
1,125
Good Morning Everyone, I'm looking to use the GSV instruction to get I/O fault codes for my project so I know if there's a comms issue in my E/IP...
872
