RSLogix5000 Print?
PuJo
Aug 2015
Louisiana
Morning all,
In RSLogix 5k, is there a way to print the IO configuration?
I thought I could get that info saving as the L5K but I didn't see it in the L5K file, or maybe I missed?
Anyway, just trying to print the IO config if anyone knows...
Thanks,
PuJo
Not sure if this is what you are looking for... but if you click File there is a selection that says Generate Report. This is configurable maybe you can get what you are looking for in there.
Hey guys, I know I'm new here, and I tried the search button, but no luck. Perhaps I was searching for the wrong keywords... I'm currently...
5,442
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
124
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
428
Hello everyone, I have an RSLogix5000 project which is running live in the factory but I need to make some changes to the logic. I want to test...
1,125
Good Morning Everyone, I'm looking to use the GSV instruction to get I/O fault codes for my project so I know if there's a comms issue in my E/IP...
872
