RSLogixs 5K DeviceNet Programming Example
mlkilby
Jan 2009
Trenton, Ohio
Hellow I am looking for an example of the Tag configuration or UDT to communicate ControlLogix via DeviceNet to a Mitsubishi FR-E-700 series drive. :cool:
Not sure if this is what your asking but AB has a program that will auto generate the ControlLogix tags from your DeviceNet network. It basically takes the info from the DeviceNet network and inserts the proper tags into the ControlLogix program you are using. Then you can use them as you need.
AB tech support should have the program for free. I belive it is called DeviceNet tag name generator. If not, I could probably send it to you
Dave
The DeviceNet Tag Generator will likely not do anything particularly helpful for you with that Mitsubishi drive.
EDS files need to have the Tag data added to them for the Tag Generator to know what data elements are included in the Assemblies used by the device. There's been a lot of work at A-B over the past three years to update EDS files to include this data.
But I have not seen any competitive gear that has done so.
Post a link to the Mitsubishi DeviceNet adapter documentation and a Forum member may be able to help you build your own UDT that matches it.
Hi all when i try to download the test code to emulate , this message appear Server busy This action cannot be completed because the other...
1,179
Can anybody give me a price range for the RSLogix 5000? I don't seem to be able to find the price. I need a ballpark figure to present to my...
3,810
Hi. We've been asked to do an upgrade on plant, consisting on a PLC upgrade. This involves replacing a 1747-SDN module to a 1769-SDN, in a network...
39
Hi there, I have above mentioned VFD which is communicating to my control logix(L62) plc using devicenet DNB scanner(plc side) and 20-comm-D card...
126
Hi, I am looking to migrate some of our Electronic Overloads off of a Troublesome Devicenet Segment. Is there any documentation confirming the...
138
