RSNetworx and 1769-SDN DeviceNet module
The "Scanlist" configuration method of DeviceNet is very old-fashioned and comes from the heritage of how DeviceNet was grafted onto the PLC-5 and SLC-500 as an expansion module with a large PLC memory data table.
You don't see ordinary DeviceNet I/O modules in the RSLogix 5000 tree with DeviceNet like you do with ControlNet and EtherNet/IP. The exception is safety modules; the Safety connection works differently than ordinary DeviceNet general-purpose I/O connections.
Instead you configure the scanlist entries in the Scanner, then "map" the data into the PLC I/O data tables or Module I/O Tags.
There's a semi-automatic way to create device-specific data tables using the DeviceNet Tag Creation Tool. I don't recommend it for just this small network.
Instead look at the Scanlist and be sure the I/O connection is created and that its resulting Input and Output bytes are mapped into the Input and Output data tags of the CompactLogix.
Thanks Ken
I have the IO module in scan list, after some try and error I think i was able to configure the module, used MSG instruction to change parameters of the IO module:
Actually PLC can change the value of Heartbeat parameter of the IO module, but for some reason, it is not possible to change the Outputs Values parameter that I tried to use it to turn ON and OFF the outputs of the IO module, that parameter is locked and I wonder how I can unlock it!
The Output is part of the I/O connection and it will be commanded by the bytes mapped to the Output tag in the scanlist.
That's why it shows as Read Only in the Parameter Editor in RSNetworx.
I think the I/O map should be right. I set all 8 outputs to 1 in RSLogix5000 project but all outputs of the IO module are still OFF,please have a look at the all configuration I did:
Have anyone met this issue that you cannot see the devicenet scanner via RSlinx or RSnetworx? I am using 1769 SDN @ node 1 on compactlogix. For...
11,241
I am getting random comm loss (error code 561 i think?) anyway i looked it up and its loss of comm to 2 modules on a controlnet network. The 2...
352
The back story: We have one customer that has some equipment that uses DeviceNet that must remain in place. On those (5) DeviceNet networks they...
895
Hello. If anybody has seen this before and could provide some clues I and some other people would be extremely grateful if you can share such...
1,341
Hello guys, Am currently working with AB studio 5000 v30 but am having problem communicating with a remote I/o module. I also discovered I...
1,389
