RSView 3.20 trend and tag import
sapoleon
Aug 2003
salta, salta
315
Hi all, it´s been a while... I just started independent, and after almost a year, I got my first client....
So, the problems begins.
My project, is to write a almost new application in an SLC500 (rewiring) and an almost new application in RSView 3.20
With the PLC, no problems, because it´s all from zero.
My first problem with RSView, is that I didn´t work with it. :)
Now the reality, I have a copy of the directory with a xx.sed file and the project.
I open a new project, and try to import the project, but always get a Unable to create HMI server, and that is when trying to import the tags.
So I create a new proyect, and start importing everything separately. I can import everything, except the TAGS. Even trying in RSView 4.00.
. Can someone point out why can that be? maybe I need to create devices first or something like that (worked a lot with Cimplicity)
The second problem I got, is with the Trend screens, it seems to be missing an Active X, and I don´t know where to get it. The trends are blank, and I gget a CAB file missing on the server: http://localhost/RSViewActiveXControlSetup/RSTXView3ocx.CAB
Trend: Newer file versio of ActiveX control required
I will appreciate any input.
Thanks a lot
The first thing I would need cleared up is,
The RSView is it
RSView 32, or
RSView SE ( now know as Factory Talk SE )
as your file extension does not gel with me unless it might be a SE Developement file
The 3.20 is this the version number of the RSView 32 or the RSView SE or , is it the Trend X which is an add on th RSView 32
It is quite likely your version numbers may be off as version 3.20 in RSView is both flavour will probably be 5 or more years old.
Hi Gil,
It is RSView SE 3.20.00 (CPR 6)
I know is an old old version, but it is what this people have, and they don´t want an upgrade. Unfortunately, they are happy with it. Also with the PLC.
What I don´t know, is the TrendX version. I think it is the AddOn, but I don´t really know RSView. I already installed the last TrendX that I found in Rockwell, (3.45.00 CPR9 SR1), and still I get that message.
And I am looking, and still don´t know how to add a TrendX object. I just see the normal trend....
Still working on it
Does any one know how to Get a tag Desription to show up in the trend legend with out retyping them in. Thanks
3,435
Respected Members rather Mentors, I am cracking my head to sort out an issue regarding RSView32 Trend object. In that trend, assigned flow...
1,780
i add new computer to our network and install Rsview 32 7.20.00(CPR7), Rslinx gateway 2.42 build 18 and Rs Trend x 3.42.00(CPR7) after running...
21
5,163
My trend graphs have disappeared on my server. I dont seem to be serving them anywhere. The graph starts trending as soon as i click on it. Coming...
2,483
hi friends, In one of my project i am using RSVIEW32 for SCADA, in which i want to record/ monitor some critical instruments datas, anyone please...
1,513
