RSView 32 making wrong entries in .DBF file
robbo
Nov 2005
Australia
85
Hey fella's,
Searched thru the forum and couldnt find help for this particular problem.
This RSView system is making some duplications in the .dbf file, and I would like to know if there is a fix for it?
Using version 7.50 of works on a XP machine.
On the date of the 4th of the 10th, thats probably where the program has been edited, or stopped and started in the morning.
The main problem is the duplicated data like on 3rd and 4th, the 7th and 8th, and the 10th and 11th.
I started trending this data on Citect a few months ago so I could always have the correct trend data, but some of the RSview data is showing up in the wrong day compared to citect (citect info is correct - the 2nd pic attachment)
ANy ideas anyone??
attachment.php
attachment.php
It appears to me that the data that appears in your DBF file is not updating from the field first or that your readings are coming from an old cache file.
Give the info below a try just in case cache files are in conflict with your project.
A repair I do if any issue crops up, is to shut down the project, then in Windows Explorer, go into the project folder, open the cache folder, and blow away all files in that cache folder, they will be rebuilt on the next start up.
The next thing I do is go to the projects Tag folder, and look for one file with "the project name".cac
I THEN BLOW THAT ONE ONLY AWAY, leaving all the other files in that folder, this .cac file also will be rebuilt on project start up.
Then shut down computer and reboot and run your project.
I cant promise this will fix your problem, but it wont harm it either.
ok, cool - will give that a try today and see how it turned out Monday.
Have done the .cac removal before with ME problems I have had in the past,
Cheers :)
ANy ideas anyone??
Yes, as Gil said it appears you are looking at apples and oranges. Your Citect data is apparently a days summary (based on a time period), where some of your RSView data trend appears to be collected based on the value of some tag or tags - the "B" and E events - maybe Begin and End? (then a periodic task at the end of the day at 23:53 - the "S" events).
Good catch Lancie
Robbo
Go to the Help - On line books - User Guide , chapter 16 , Sharing data with
other windows applications , that's on pages 581 to 584 in my book
Give descriptions for , B , E , S , U , E .
B began logging
E end logging
S snapshot
U uninitialised
S stale data
Yea looks like the log triggers are radio buttoned for 'on demand'
On saturday, I might make a seperate one set to 'periodic' and see how that goes.
Thanks for the help!!
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
297
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
252
Okay, something I have not seen before.. RSView SE. I am working on an existing project. There is a value the customer wants trended and it is...
811
I have a request to integrate a pause button in RSlogix to be able to start/stop a video. Video format is not defined at the moment, so it could...
794
Hello everyone, I am having a problem with conversion from RSView32 to FT View SE Local project on version 12.00 (CPR 9 SR 12). Firstly, I have...
1,407
