Rsview 32 on trial period
Aug 2018
NAVI MUMBAI
Hello everyone ,
i am communicating RSVIEW32 software with micrologix 1400 plc over DH485 protocol in trial period.But unable to get/read values from PLC tag, anyone know how to use RSVIEW32 in trial period???
please do needfull !!!
thanks & regards,
Rutesh Deshmukh
Do you have the rslinx drivers installed?
if memory serves me correctly, you have to have licensed software for everything to work. I can be wrong, please read the manual to see what is allowed in trial mode.
if I am wrong, someone please correct me.
james
james
If my memory serves me correctly you get a limited tag count, like 100 or so. And run time limit.
james
If my memory serves me correctly...
There is no "Trial Mode" as such for the RSView32 software. There is "Demo Mode", or the "Grace Period".
If the software has been running using a valid Activation, and when opened it cannot find the Activation, it will enter the 7 day Grace Period. During the Grace Period the software will continue to run as normal with no limitations, including the number of device tags allowed. The user will, however, be periodically prompted that the software is currently running under the Grace Period and the remainder of the 7 days will also be displayed.
If the 7 day Grace Period elapses, then the software changes to Demo Mode. In Demo Mode, the application will run for 2 hours before the Server is automatically shutdown. The Server may be restarted and the next 2 hour period is started. During Demo Mode, the tag limit is restricted to 35 device tags.
That is, again, if my memory serves me correctly.
Regards,
George
Regards,
George
That sounds more like it, I know there is a tag and run time limit. I also vaughly remember something screwy too when you try to open a large project in “demo” mode, are you trying to do this?
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
325
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
267
Okay, something I have not seen before.. RSView SE. I am working on an existing project. There is a value the customer wants trended and it is...
819
I have a request to integrate a pause button in RSlogix to be able to start/stop a video. Video format is not defined at the moment, so it could...
799
Hello everyone, I am having a problem with conversion from RSView32 to FT View SE Local project on version 12.00 (CPR 9 SR 12). Firstly, I have...
1,416
