RSview cleaning tags
Mathias
Feb 2004
20
hi guys,
is there a way to "clean" RSview32 from double or unused tags,
my ethernet connection is beginning to get very slow and there is only one SLC5/05 a RedLion panel and two computers connected to the system,
we do have 1890-something tags
any help on boosting up the network is appreciated,
thanks,
Mathias
Sometimes, a good way to clean out a database file (Note: no brand name mentioned) is to export it to a .csv or spreadsheet file. If you have a spreadsheet program, it will let you diddle with the database a LOT more because it doesn't have the security features of a database. You can do mass edits of tags (including delete) without clicking each tag one-by-one, and then import the file back in.
If you're deleting tags, you'll need to completely wipe out the original database (if that can be done) before doing the import. Otherwise, you'll only succeed in updating existing tags. So, SAVE YOUR WORK AND DO A TRIAL RUN FIRST if possible. Toss the spreadsheet file when you're done. You don't want to see what can happen if you use a spreadsheet program to manage a database!
AK
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
329
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
272
Okay, something I have not seen before.. RSView SE. I am working on an existing project. There is a value the customer wants trended and it is...
823
I have a request to integrate a pause button in RSlogix to be able to start/stop a video. Video format is not defined at the moment, so it could...
804
Hello everyone, I am having a problem with conversion from RSView32 to FT View SE Local project on version 12.00 (CPR 9 SR 12). Firstly, I have...
1,424
