Rsview double click problem
tgaljar
Apr 2006
Virovitica
69
Hi everyone,
One question about Rsview32. How to trigger an action (set a tag) with double mouse click. I've seen ActivX control (Dblclick) for this action and it works fine for objects like buttons but what can I do if object isn’t button than just some triangle or circle??!?
Thanks!
Select the object, right click, animation, "touch". This will make the object a 'button'. Not a double click option but a single click change.
Unfortunately, I don't believe that you can do what you are asking with a standard drawing object (circle, square, etc.).
I do not have RSView32 installed on my PC, but I looked at the drawing objects in RSView SE (which work in much the same way as RSView32 objects). It does not appear that you can attach VBA scripts to a drawing object.
Rick
OK I solved the problem. You cannot make you own shape of ActiveX object, but ActivX object can be a picture. So I draw triangle in Paint with a background colour same as background in Rsview. Like this ActivX object (picture of triangle) looks like triangle but in fact it is square.
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
327
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
269
Okay, something I have not seen before.. RSView SE. I am working on an existing project. There is a value the customer wants trended and it is...
819
I have a request to integrate a pause button in RSlogix to be able to start/stop a video. Video format is not defined at the moment, so it could...
800
Hello everyone, I am having a problem with conversion from RSView32 to FT View SE Local project on version 12.00 (CPR 9 SR 12). Firstly, I have...
1,416
