RSView Gauges with 360º sweep
Aug 2007
Saint Augustine, FL
178
I've been told that I absolutely have to have a full 360 degree gauge on my HMI, and as you are all aware, out of the box, RSView seems quite happy with 180 degree half-moons.
I suspect I need to create/purchase/download an ActiveX control, or something, so I thought I'd ask you fine people what you do when your checksigner asks you to do stuff beyond the normal bounds of RSView.
Any good source for third party, RSView-friendly ActiveX's?
You should be able to create your own or modify an existing gauge graphic to do what you want. The needle portion will have a rotation animation which is probably set to 180, simply change it to 360 and modify faceplate to show a full 360. ActiveX seems overkill.
I don't seem to be able to edit the built-in gauge control.
However, are you proposing I simply include a "faceplate", and then create a needle out of a line and apply animation to it?
... i hadn't considered that.
Yes, it is as simple as that. Create/copy a faceplate and a needle. Apply a rotation animation of 360° to the needle.
I know this isn't helpful but why do they want a gauge? It takes up a far too much space for the information that it conveys.
Putting guages and selector switches on a HMI/SCADA screen is like putting a saddle in your car so it seems more like you are still riding a horse. You could do it (and likely will have to as it is demanded by the customer) but why would the customer want to?
I respectfully disagree as to the utility of analog gauges. While a numerical readoutout can give a precise indication it must be interpreted against limits as to its value relative to an optimum state.
A properly designed analog gauge with colored sections can give a 'too low' 'ok' 'too high' indication immediately. The rate of rising or falling of the indicator can give a feeling of the dynamic conditions of a process far faster than interpreting number changes.
While a numerical readout can be set to give different colored backgrounds for the limit indications this, essentially, does the same as the analog gauge. If the vaious nemerical readings of a state are equally important then a pure numeric readout is the preferred device.
now that's funny...
I have seen some operators actually run the process by watching a trend screen.
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
325
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
268
Okay, something I have not seen before.. RSView SE. I am working on an existing project. There is a value the customer wants trended and it is...
819
I have a request to integrate a pause button in RSlogix to be able to start/stop a video. Video format is not defined at the moment, so it could...
799
Hello everyone, I am having a problem with conversion from RSView32 to FT View SE Local project on version 12.00 (CPR 9 SR 12). Firstly, I have...
1,416
