RSView Keyboard display
jerry_smith
Feb 2004
21
Hey guys,
I have an RSView project loaded in a touch panel display. It has an operator login screen which comes up first. I need a software keyboard which will get displayed along with that screen. When i selected the "display keyboard" option in the display properties, it just gives a Num Pad with the entry field. How can i display a alphabetical keyboard with the window. can u help me on this?
js
The RSView resource kit contains the easykeys application that gives a keyboard you can use. It is a separate installation from RSView so you may not have it installed.
How can i make it work? I have a button "Operator Login" which when pressed displays the RSView32 Login screen with input screens for username and password. So i went there and gave a Appstart "C:\Prog files\...\Easykeys.exe" in the Release Control box. But when i try to run the project and press the "Operator Login" button, it just displays only RSView32 Login screen.It doesnt show the Easykeys application.Should i do anything special to make it work?
This doesnt work too.
AppStart "C:\Program Files\Rockwell Software\RSView\RsvLogin.exe /C"under Release action.
I dont see any windows popping up when i hit "Operator Login"button in the Run mode.Iam using an inprocess OPC and right now iam not connected to the PLC. Iam just testing the HMI. But when i use "Login" under Release action it Pops up.Can u see any problem here?
Thanks for ur help,
js
There is a separate login executable included with the resource kit. This one includes a keypad on the popup window. I guess the login command doesn't have the ability to use the keypad so this one was created.
Is this not the Login executable with RSView32?
When i do an AppStart on this it simply doesnt pop up. nothing happens. It would be great if i can use this. This satisfies all my requireents. Should i use anything other than Appstart to invoke this?
Thank u
js
Looks like RsvLogin doesnt work for my version of RSView32 6.50. I will have to look for some other way. Thanks for ur help.
js
I don't know. After you posted that you were having problems with it working in 6.5 I went to the knowledgebase to see if there was any issues. I couldn't find any. I'm running 6.4 and it works fine.
The only other thing I could think of is if you were using an older version of the resource kit. I think I'm using 3.28.
I'd call tech support if you're still having problems.
grs
Are you running this application with a windows operating system, I am running the rsview on a Allen Bradley Versaview touch screen computer with win2k and use the windows program, START/PROGRAMS/ACCESSORIES/ACCESABILITY/ON-SCREEN KEYBOARD and it works fine.
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
327
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
270
Okay, something I have not seen before.. RSView SE. I am working on an existing project. There is a value the customer wants trended and it is...
820
I have a request to integrate a pause button in RSlogix to be able to start/stop a video. Video format is not defined at the moment, so it could...
800
Hello everyone, I am having a problem with conversion from RSView32 to FT View SE Local project on version 12.00 (CPR 9 SR 12). Firstly, I have...
1,417
