RSview ME - Ran out of macro global connections
westec
Jun 2006
Manitoba
Situation: I am upgrading a project in RSview ME. It uses RSview Station on a PC. I need to total values using macro's based on outputs from the PLC. Since RSview ME only allows 5 marco's to be lauched in the global connections, I've run out. I really only need one more.
Question: Is there another way that anyone knows of that will let me lauch a macro from an output in the PLC logic? Or (silly question) add more global connections?
More info: The PLC itself cannot do the totaling as there are far to many memory bits involved (>1500). Thus I am using RSView tags on the PC.
The PLC is a modicon (only have modsoft 2.X on an old win95 machine for progamming) and I am using kepware server software to bridge the communications.
Still looking for an answer. I have a question to Rockwell's engineering team. Hopefully they can help. Anyone else have any trick to run a macro from a output/tag aside from using a global connection?
I have my answer from engineering. 5 Global connections is the max, that's it, for executing Marcos. Everything else needs to be operator initiated.
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
314
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
260
Okay, something I have not seen before.. RSView SE. I am working on an existing project. There is a value the customer wants trended and it is...
814
I have a request to integrate a pause button in RSlogix to be able to start/stop a video. Video format is not defined at the moment, so it could...
798
Hello everyone, I am having a problem with conversion from RSView32 to FT View SE Local project on version 12.00 (CPR 9 SR 12). Firstly, I have...
1,413
