rsview+ rslinx lite +rs logix emlate+rs logix microstarter
RSView32 doesn't work with RSLinx Lite. You need a higher level of Linx. I have only use RSLinx Gateway with my toolkit so I don't know all the different levels, sorry.
Hope this helps
Since this looks like a student project, you might only need to get it working for a few days.
The first thing I would do is attempt to install RSLinx Classic 2.58 onto a fresh computer (preferably a Virtual Machine) so that it goes into "Grace Mode" as RSLinx Classic Gateway and will serve local and remote OPC Clients.
The other thing you could try is to use a "virtual COM port mirror" to connect an RSView32 Direct Driver node to the RSEmulate 500 emulated controller's serial port.
Do you have the ability to install RSLinx Classic onto a fresh computer, or to attempt to use a COM Port Mirror utility ?
Can anyone please help as i have ben struggling now to keep RSView running for more than 48 hours as continuous use required by the client. The...
5,441
Hi Everyone This is my first post, I will try to give you as much information as i can, but am not used to rockwell products. I have an...
4,482
Welcome to Automation World, Dear viewers and experts, I am facing a problem in RSVIEW MACHINE EDITION. I am running one rsview machine...
3,917
Hi Folks ! I want to show up 5 Array of 200 Reals in Excel. Normaly I make a direct connection from RSLinx with copy and paste. For example...
3,181
When I start up FactoryTalk View Studio, I get an error box labeled RSLinx Enterprise. It says: "An internal error has occurred. You must close...
9,073
