RSView SE - Stupid Question
Hucklebarry
Oct 2007
South Carolina
How do you determine which display is loaded on power up?
I can't find it anywhere in the help file. I can't find it anywhere in the KnowledgeBase. In ME it's simple. But, I can't for the life of me find it in SE.
Anybody?
Thanks.
I don't have it on this machine but you have to right click [ I think the HMI server in your project] and it has start-up properties. Sorry but I am going from memory. If you don't have an ans when I return I start-up another computer and let you know.
Hope this helps.
I don't see it. Server properties opens a box with two tabs. The "General" tab only has name and description. The "Components" tab lists startup components, but nothing about startup screen.
Am I blind?
It has been awhile but you set your initial display when you configure the client in both Network and Local apps.
So once you build your app and you want to test it you can click on Launch SE Client and configure from there or click Factory Talk View Site Edition Client and point it to your project.
If this is now clear as mud let me know I and I'll try again.
Hope that helps.
Just to clarify....the application does not have a start-up screen since in essence it should not be powering up and down. Each client machine (thus the client config wizard) could have their own start-up screen so that when that client launches they see whatever screen is appropriate for that area.
Remember that Studio is for development. You actually view the running application in the client.
OG
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
301
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
258
Okay, something I have not seen before.. RSView SE. I am working on an existing project. There is a value the customer wants trended and it is...
811
I have a request to integrate a pause button in RSlogix to be able to start/stop a video. Video format is not defined at the moment, so it could...
797
Hello everyone, I am having a problem with conversion from RSView32 to FT View SE Local project on version 12.00 (CPR 9 SR 12). Firstly, I have...
1,408
