Rsview Studio Tag Renaming Issue
PLC Gremlin
Aug 2004
TN
80
Hello all,
Can anyone tell me if there is an easy way or even a way at all to rename a bunch of tags in RSview Studio 4.0. In the Tag editor it will not let you simply change the name of an existing tag. Would I have to create a new tag and copy the addresses into it or what. Seems like that would be an awfully cumbersome task to perform on a lot of tags just to get them renamed....
any help would be appreciated..
Thanks..
My advice is to export the tags to a CSV file and rename using Excel's find and replace function. Easy and quick, just make sure you export what you have now first so you have a backup if things go wrong.
Hit "CTRL-A" to select all on a screen.... Then I think its "ctrl-T" or "CTRL-R" and a search and replace screen will come up.
Its been a year or two since I used rsview studio so just running from memory on the keys...
hello,
in the rsview software while in the tag database screen. highlight the tag that you want to rename and choose to duplicate the tag, once you do this the tag name section opens back up so you can then change the name of the tag. then you are free to delete the old name tag if you wish.
hope this helps if you are still having the issue.
Hi Guys, Is there a tag search function in RSView Studio similar to the old function that was available in Panelbuilder 32 where you could...
3,043
Hey Guys , why if I am creating project for Panalview1000+ ( using studio) and on one of my screen there is a button "Start-Stop machine" and want...
1,409
I have RSVIEW STUDIO 6.1 and RS5000 R19. If I have the tags created in RS5000 and work on a screen in RSVIEW, I can see those offline tags...
6,061
I have created a Compactlogix PLC program with RSLogix5000, and now want to export the tags to PanelView Plus program created with RSView Studio...
11,559
Hi all, First time poster here... until a year ago my ladder logic exposure was at a GM assembly plant in the early 80's, all on D size paper...
4,769
