Rsview tagname
MiguelCh
Jul 2006
Antofagasta
I need help with tagname, I have a screen with tagname described #1\pump_running, but my database of it has motor\pump_running
when I call the screen it appears tagname no found #1\pump_running.
since I can solve this problem.
Atte.
Miguel fron Chile.
Under Tag Monitor find your tag...the forth row over State what is the status? error? you can also press the f1 key and there is some good info on that screen that may help...
But it just looks like you have the tag addressed wrong "motor\pump_running"? the description should not change, I think it shoud still be #1\pump_running
The "#1" is a placeholder.
When you call the screen you need to provide a string to replace the "#1". You can use the "/t" switch with the display command and include the substitute or you can use the "/p" switch to reference a parameter file that can include a list of substitutions.
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
335
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
284
Okay, something I have not seen before.. RSView SE. I am working on an existing project. There is a value the customer wants trended and it is...
828
I have a request to integrate a pause button in RSlogix to be able to start/stop a video. Video format is not defined at the moment, so it could...
808
Hello everyone, I am having a problem with conversion from RSView32 to FT View SE Local project on version 12.00 (CPR 9 SR 12). Firstly, I have...
1,435
