RSView32 Datalog
hazey
May 2003
Australia
73
Guys I have a server running RSLINX(oem) only, it is connected to controllogix platforms. Then have 3 other computers running RSView32 clients connected to server running RSLINX. Is it possible to continue to datalog when all the client machines are turned off? At the moment the clients all log to their own c directory. I think the paths for dataloging on these machines should all point to one file is that correct?
thanks
Hazey
Hi Hazey,
If I'm understanding you correctly the answer would be no. Rslinx is a communication software that creates the bridge between the PLC's and the RSview clients and RSview does all the datalogging. On the client machines you can check the paths of the datalogging to see where the data is being sent when they are on by clicking the "path" tab on the "data log setup" screen.
One possible way to log while the clients are off is to install RSview32 or RSSQL on the RSlinx server (that is if the server still sees all the PLC's when the clients are off).
Hopefully this is of some help
Good Luck
As pc_geek suggested, that exists. It's a separate program, not an RSLinx plugin. You're looking for a "historian", RSSQL in the Rockwell world.
You want to use an SQL database as opposed to writing to a common network path. The former is designed for concurrent access. As you suggested, at least 1 on the computers (hosting the data logging application and SQL database) would need to run to ensure continutity of data, but individual clients need not be up. A more generalized data logging application like FactorySQL could also be used to put your data into the SQL database.
One thing for you to check out - I'm not sure if your RSView clients can view historical data logged from RSSQL. There might be a plugin to support that. If you were running the distributed version of RSView (SE), this wouldn't be an issue.
hazey said:
Yeah I just wondered if there was on add on for RSView to datalog seperate to running client.
thanks
Hazey
Hi, I have same system connected to 2 PC's running RSView32 SE (old)and another with Factorytalk SE (new). I next few months old one will be...
1,516
A client is running an RSView32 station strictly for trending and reports, but the station hung up the other day and had to be ctrl+alt+del \end...
1,457
why does rsview32 dataloging suck so much..i cant seem to get it to trigger when i want on a tag and when i pull the datalog file its so long and...
5,487
hello all! i have a rsview32 project that is logging my info for the day, i was wondering how can i create a button that simply says print...
1,817
Hi Guys i have to get the datalog off the rsv project on to a usb every week, is there a way i could config a button to copy the files straight to...
1,387
