Rsview32 .DBF files - I need to chart a bunch
ironsham
Nov 2007
Cleveland
I have to produce charts for a month's worth of these dbf files. There is one file for each 6 hour cycle.
Anyone have any ideas?
I could open each one individually into excel, copy the data to another sheet that already has a chart set up, and then Save As, but this will take forever. There are over 200 of these, with temperature data in one file and kilowatt data in a seperate file. ughh
I don't know much about VB, so I might be better off just biting the bullet and getting it done.
Any suggestions would be appreciated
Do you need the values? or just a picture/trend?
You could make another RSView project to open them and display them, but depending on how fast you are at making new projects this may take you just as long, but if you are going to do these forever then it may be your best best...
Thank you for the reply
I Just need some type of summary. I suppose a chart that gave a clear idea of the maximums and the average would be sufficient.
I'm not doing these forever, just for this one customer one time who wants to upgrade one location's equipment to be on par with another.
I'll give it a shot with a temporary rsview32 project, see if I can get things done any faster.
Are your DBF files in wide or narrow format ??
I suspect that when you say there are 200 and then you say they are in 2 files I suspect they may be in narrow format.
If so then in Excel put them through a pivotal table and each tag named value will be sorted basically into wide format.
Hi, I have same system connected to 2 PC's running RSView32 SE (old)and another with Factorytalk SE (new). I next few months old one will be...
1,516
Greetings all,I have an existing RSVIEW32 project that is running on a computer which is connected to our "production network". The production...
3,344
Hi, I would like to create a vba code to format the dbf files that RSView32 creates to make readable reports. For example, if I datalog a tag, I...
17
12,509
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
377
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,914
