RSView32 ODBC
antonlee
May 2008
Hamilton
Can I setup RSView32 to log data using ODBC to a table with more than one field? ie Descripton, Operator Name etc. I want to be able to do this in one table and not to create several Datalogs per field.
Is this possible in RSView32 or do I have to have different data logs setup for each field. The fields are setup as string inputs in RSView32 graphic.
I do not know how to send the data to the specific fields inside the odbc table.
Cheers.
Yes you can do this using VBA. I would personally use ADO rather than ODBC if this is possible. There are good examples on the Rockwell website for this and it is realtively easy to do and very reliable. If you are using a database which supports stored procedures you could simplify the RSView end still further and just pass parameters to the DB. I do this where I am collecting data from different sources so I always have a common date/time stamp (from the DB machine).
Andybr
By default, RSV logs to 3 fields float string & tag index, you can create more than one but store them to the same DbYou can rename them but there is always the 3 fields however some need not be populated.
As above it would be best to populate the DB with VB.
Hi, I have same system connected to 2 PC's running RSView32 SE (old)and another with Factorytalk SE (new). I next few months old one will be...
1,520
Can anyone tell me what is wrong with this code!!! It seems to be hanging-up on the string. I can take the string commands out and it works...
2,290
Hi!! I have MYSQL v5 Serwer on WinXP Pro, with installed MyODBC Driver v3.51.12 and a RsView32.. And I would like to log (by using Datalog)...
4,059
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
384
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,920
