RSView32 + OMRON = ???
ade
Mar 2005
Bandung, West Java, Indonesia
46
Hello everyone!
I am currently playing with RSView32 and OMRON CPM1A PLC.
My target is to access both read and write from/to OMRON CPM1A PLC from RSView32. Serial communication (CIF01 HostLink) is used.
My questions are:
  1. What is the good protocol to facilitate this RSView32-to-CPM1A communication (I know we can use RSLinx with AB's products)?
  2. I have FinsGateway, but there is no "SerialUnit" option in the "Network/Drivers". How to add it?
  3. In the RSView32, what kind of node I have to use, OPC or DDE?
Please give me some clues, so I can play with them.
Any comments, suggestion, clues would be greatly appreciated.
Thank you!
-ade-
Thanks for the info and link. I do really appreciate that.
Unfortunatelly, the OMRON CPU I mentioned (i.e. CPM1A) is not listed in the supported-devices in the link you have given me.
Thanks;)
I need to interface an Omron PLC to RSView32, need is immediate. I'll have to use the programming port and cable as the RSView port is connected...
2,112
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
391
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,923
Hi Guys I'm having trouble assigning a tag to an activex label on a Multipage Tab. I can assign the tag to an active x label on a normal display...
607
I have followed the procedure below to convert RSView32 project to FactoryTalk View...
1,449
