rsview32 running project on the laptop
stu
Aug 2005
England
786
Hi Good people
i have made some adjustments to a project and i would like to run it on the laptop before i put it on the machine.
i am using ethernet as the connection i can see the plc in links but i can not retieve the data on the hmi?
is there anything to look out for?
thanks stu
yes i have, i took a copy of the project from the hmi and adjusted the screens ect but i cant see why it will not run online on the laptop?
I think classic should work, not sure about Lite. But once again, forget the RSView project, did you create the communications topics in RSLINX on your laptop?
Backup your linx on your HMI machine and try restoring that config on your laptop. That might help.
i am not to sure how to set one up, could you give me step by step instrutions please
thanks stu
It is possible that a backup (from the running HMI machine) and restore (to your laptop) might work as iggy mentioned. Try that first. From the 'Start' menu, go to RSLinx, use the "RSLinx Classic Backup Restore Utility" to create a backup of the running configuration, and then use the same utility to restore it to your laptop. I tend to avoid doing this mostly so I don't bring in more than I need.
To create a topic, open up RSLinx itself, go to the menu "DDE/OPC", select "Topic Configuration", select the "New" button, give it a name (the same Access Name as the HMI project is looking for), then browse to the target processor, and hit apply. Once created, you can adjust the minimum polling rate for polled messages under the "Data Collection" tab.
Hi all, Is it possible to run RSView32 project from a CD? I understand that some files/folders should not be read-only while RSview project...
6,586
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
392
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,924
Hi Guys I'm having trouble assigning a tag to an activex label on a Multipage Tab. I can assign the tag to an active x label on a normal display...
608
I have followed the procedure below to convert RSView32 project to FactoryTalk View...
1,451
