Your initial graphic could be being determined several different ways. In the RSView32 Works project, under the edit tab, expand the System folder. Then click Startup. Then select the startup tab and set the startup graphic. This is the first graphic RSView will load, but its not necessarily the graphic that you will get after RSView is loaded and running. On the startup tab you'll also see a startup macro. If one is defined it could be also loading and displaying a graphic. Finally, whenever a graphic loads it might also call a macro, and that macro could activate a different graphic. You could also have an event defined that loads a particular graphic. In any case, the place to start trying to figure out the problem is on the startup tab, then look to any macros and or event files configured on the startup tab.
