RSView32 Works startup question
George Graziano
Jul 2004
NY
447
When I start up RSView32 Works and start the project, the wrong graphic is coming up. Is there a keystroke to close that graphic so that I can start the correct one? All the clients are fine, only on the server is this an issue.
George
Your initial graphic could be being determined several different ways. In the RSView32 Works project, under the edit tab, expand the System folder. Then click Startup. Then select the startup tab and set the startup graphic. This is the first graphic RSView will load, but its not necessarily the graphic that you will get after RSView is loaded and running. On the startup tab you'll also see a startup macro. If one is defined it could be also loading and displaying a graphic. Finally, whenever a graphic loads it might also call a macro, and that macro could activate a different graphic. You could also have an event defined that loads a particular graphic. In any case, the place to start trying to figure out the problem is on the startup tab, then look to any macros and or event files configured on the startup tab.
Aleric,
Thanks, I did go to the system and selected the one I wanted, but as you say there are other ways after that. I will check in the morning. Once the wrong graphic comes up thou, how can I close that one and select another?
Aleric,
There was a startup Macro. I played with it a little this morning. It is better, not perfect. Also, I was told to try <CTRL> <ALT> <P>, to get out of that graphic. It worked but only after I did it twice.
George
what's the difference between Rsview ME and RSVIEW32 works and can'i migrate a RSVIEW ME project to FActoryTalk !!thnx....
1,584
Have a server running RSView32 Works. Somehow the Menu got screwed up and when you start the program, If you don't select the right screen (with...
2,983
Is it possible to import trend data into an existing project? I have previous trend data and would like to import it into the current project.
2,036
Hello all, I'm new to the site, but thankful it's here! I just installed RSView32 on my computer for the first time. I have never run any...
9,371
Hi, (RSView32 Works v7.50) I have a problem with exporting and importing of graphic files between projects. I export graphics from one project...
4,218
